Clutch Push Rod
So I had the clutch push lever out of my 2005 WR 450 to fix some case damage from a broken chain. When I put it back together the clutch push rod doesn't push the pressure plate out far enough to disengage the clutch. I checked the parts diagram and nothing appears to be missing (the ball, bearing and washer are present). If the push rod assembly were about a 1/16" to 1/8" longer looks like everything would be fine.   Any clues?   Thx!
