Broken kickstart retaining bolt
Somehow sheared off the bolt that retains my kickstarter.
Tried center punch, drill, easy-out but could not get the easy-out to bite into the broken bolt.
Tried using a torx bit in the center-drilled hole. Broke off the torx bit in the hole. SOL.
How hard is it to replace the kickstarter shaft? Looks fairly straightforward.
What parts are common for 2015 kx450? OEM for that shaft is $93 but can get 2008 assemblies on ebay for 60-75. Will the 2008 fit?
Thanks!
Take out the shaft - alot easier to get the broken bolt out - pretty simple job. Take it to an engineering workshop or someone that can get that bolt out.
But then again might be cheaper just to replace the whole shaft.
2009 - 2015 shafts a interchangeable - bummer dude
Yep, that's what I figured. Machine shop can get it extracted, but needs the shaft out and disassembled and will charge $65. If I'm that deep, might as well replace with a new shaft. Ordered from RMATV and will be here tomorrow.
For those wondering, the clutch hub nut is 30mm and will come off with an air impact gun. Otherwise, would need the hub holder tool.
