Transmission Shaft Removal 88 RM250
Can anyone offer suggestions on how to get the shaft within the case out of the bearing? I will include a photo of what I'm taking about. I have removed all the gears and circlips but I just cannot get that shaft to free from the bearing. Should I heat the bearing race holder screws up and just remove the whole shaft and bearing together then try to remove the bearing or can I get just the shaft out?
Peice of wood and whack it probably don't have to hit hard lol or brass hammer, rubber mallot my do it :thumbsup: I've even used my palm
Edited by Motox367
Tried everything but ended up getting pissed and whacked it with a 3# sledge and out it came! No damaged either except I broke the bearing retainer in the engine. I was able to get the screws out also which I couldn't do yesterday! Also had to cut the bearing off the shaft as it was seized on there.
I like the blue paint inside the cases, they don't make em good like that 'nymore...
