Need xr100 stator. Can't find anywhere
Hi everyone,
I'm rebuilding a 1991 xr100r engine and I don't have the stator for this bike.  I have searched online a ton with nothing coming up.  eBay I have been monitoring for 3 weeks haven't seen one for sale.  Will I be able to find this item?
Looks like this for reference.  Anyone know where I can find one?
Thanks Brad
Edited by Brad Thompson
81 - 91 are the same
Assemblies where 31120-KA9-005 is used
1981 XR100 A
1982 XR100 A
1983 XR100 A
1984 XR100 A
1985 XR100R A
1986 XR100R A
1987 XR100R A
1988 XR100R A
1989 XR100R A
1990 XR100R A
1991 XR100R A
Baja Designs also do one on ebay - not sure if the connector has to be changed or not
We've parted out tons of XR100s.
Those stators sell fast for about $70
So I see the baja one
http://www.ebay.com/itm/BAJA-DESIGNS-INTERNAL-STATOR-HONDA-CRF80F-CRF100F-XR80-XR100-/222252321422?fits=Model%3AXR100R&epid=678315989&hash=item33bf454a8e:g:vtMAAOxyTMdTK0yD&vxp=mtr
However I need the metal mounting plates as well :(
You have any now laying around possibly?
Now is the perfect time to switch to a CDI.  I just bought a complete CDI on Ebay for $100.
Which one works?  I need the mounting plate as well
From 1992 on up works.  The reason I suggest it is because the older stuff is getting hard to find and pricey.  Too pricey in my opinion.  The only thing is you have to buy everything, CDI, wire loom, coil, stator, and flywheel.  But every so often you can get really good deals on ebay.
Thanks for the info.  Could you link a kit on eBay so I know what's involved?
This is the one I just bought. The key and kill switch you don't need.  The 80 and the 100 are exactly the same except the backing plate.  Right now there is a flywheel and stator super cheap, but no backing plate.
http://www.ebay.com/itm/Honda-CRF80-Crf-80-Crf100-100-04-08-06-Electrical-Ignition-CDI-Coil-Stator-Key/332278366122?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Thx for this info ,:)
I am having the same problem, I have 87 honda xr100r. I am in need of the stator and cant find the orginal one nowhere. I have been looking into the CDI Conversion. I am looking on Ebay all I see is just the wiring and CDI and igniton coil being sold cant find the stator. Any ones you found on ebay? any information will help.
couple on ebay for sale 81-91 stators will fit
If engines only doesn't sell them anymore, then what I do is use the old key, then center it and tap it in with a socket and a small tap with a small hammer.  Double check to see if it's centered, then tighten it up.  I never had an issue and all my motors are 120cc or bigger.
3 hours ago, burgermeisterklx450r said:
Does anyone know if a stator from a cdi xr100r would work on a points ignition 1984 xr100?
You need to buy the complete system.  They are about $150 on ebay.
Hi just bought a 87 crf100r and the stator is bad not getting spark where can I get the kit to do the conversion to cdi??? Please help or where can I get a stator to replace my bad one??
Hi I’m looking for the ignition coil for a 87 xr100r and can’t find one anywhere can someone please help find one or have one for sale or what are the replacement ones
