2015 350 exc motocross setup
I am going to race a motocross race tomorrow on my 2015 350 exc. stock suspension. The track doesn't have doubles or big jumps, but there is air involved. I raced a hare scramble there and part of the course was the track. I was bottoming out on some of the jumps. I am 170 lbs on stock suspension. Any quick set up tips to make my bike handle the jumps a bit better??
crank down the adjustments a few but remember its not a SX with linkage suspension.
Even though it's too late for you I imagine he means increase the slow speed compression on the rear and increase the compression on the front. This will mean it won't blow through it's travel quite as fast.
Should just leave it alone... Unless you've tested out different clicker setting specific to what your riding you'll be giving up something else that is familiar and comfortable in other parts...
Turning the clickers up a bit should  slow things down and may help  out on track, hopefully you have EU map and put on wild. good luck!
