Atc help
Bought a 1980 atc 70 had 2 original motors with it that needed odd and ends but also came with a japanese 110 electric start. I redone the whole frame and decided to go with the 110 motor so i ordered a whole wiring harness and new electrical parts hooked everything up and wouldnt even act like it wanted to start so i ran a hot wire straight from the starter which it had a prong and as soon as you touch it to the hot side it will turn over for a split second but wont start and both the hot and ground wire will get burning hot so i have to unhook them. Am i missing a ground somewhere or do i have something hooked up wrong, everything is color coded though even coming from the mag am i suppose to have a ground coming from the starter as well
