Showa rebuild questions
Bought a pivot works rebuild kit before I read the reviews of it on here. :banghead:
trying to figure out how to take the band off of the piston and I'm at a loss. It's a Showa shock off a 08 kx250f.
Is the spring that was in the seal head used with the aftermarket seal head? I'm not even sure what that spring is called.
Top out spring and mostly not used in aftermarket stuff , you have to cut off the piston band
Mog I can't thank you enough man. You've been a big help with all of this. Had to put heat to get the new band on. Hopefully didn't scratch the inside too bad.
