Battery on DRZ 400 doesn't charge - Not sure if Stator is damaged
Hello,
I am new to thumpertalk. I bought a used drz 400 a month ago. A week ago my bike didn't start anymore. The battery was empty, so I recharged it but the same thing happened again 2 days later. So I bought a new battery because I thought the old one was bad. The same thing happened again with the new battery. So I looked on thumbertalk for any solutions. It seems that the battery doesn't get charged when the bike is running. After checking the battery with a multimeter I get only 12,4 volt on my battery even if the motor is on and I am going up to 3000rpm. There are a few things that could be damaged or faulty. The adapter connecting the cables to the battery could be corroded. I checked for that but it seems to be fine. I looked at the fuse but there doesn't seem to be any damage. The rectifier was tested with a multimeter and it seems to be ok too. The only thing that is left is the stator and after checking with the multimeter it seems to be the problem since I don't get the same readings for the 3 different pins. So I removed the stator from my bike but after inspecting it it seems to be ok. No coils are burnt (or at least it seems like the stator is in a good condition). I made a couple of photos for you to see it for yourself. I don't have much experiences with these kind of things so I am not sure if I should I replace it or not or if the problem is somewhere else.
Any help would be welcome. Thanks for your replies.
You might have found the DRZ forum and it's FAQ by now, but I can give you a short rundown. You can test the stator leads while the bike is running, you're looking for 70-90 volts AC depending on RPM. Don't run the bike with the R/R output disconnected.
I had a problem with the 2-prong connector that sits on the output side of the R/R. The bike wouldn't charge because of corrosion in this plug.
