Kxf450 2009 - high idle/choke adjuster broken?
Hi, I'm looking for some help
recently had my bike re shimmed and a couple of valves replaced along with a valve guide. Bike fires up but won't idle with OR without high idle/choke engaged.
adjusting the idle dial seems to do nothing as it did prior to the re-shim etc. its as if the idle dial has broken. The bike did idle before I had the work done and the dial did work.
Would the work done have any baring on the dial be it a sensor or somthing mechanical in the head? Any help much appreciated. Thanks
