1989 XR250R Front Brake Switch Help
Hello,
I have a 1989 XR250R that I am going to convert to a dual sport. I ordered the Tusk lighting kit and the drum brake switch.
However, I do not know how to install the front brake light switch. What part would I need and how would I install?
Sorry I am a noob.
Thanks
I don't think it has a front brake switch, unless they changed the kit, it just assumes that you will be using the brakes simultaneously... and there really shouldn't be a situation where you are using the front without the rear unless you're doing stopies/endos....
For drum brakes the switch is round and fits into the leaver perch behind cable adjuster this pic I just took is of my 83 xl250r has drum brakes my finger is pointing at the brake switch in the purch  hope it helps  :)
2 hours ago, Undercover Poe said:
Pick up a perch and lever from a NX or XL or any other street legal bike that has the switch and use that
Yep, there's one on ebay for $27 right now (search XR250L front brake).
Or, use a hydraulic brake switch for $8 - $10.
Only problem with a hydraulic switch is  where do you put it on DRUM brakes????:rolleyes:
Or get ANY nissin maser cylinder front brake light switch for like $3. I have a handful if youre in SoCal. I dont even see a brand new best kind one for less than $10.
How do you plan on getting direct current?
Grr. I just forgot...R...is there two holes (one threaded) under your master cylinder? Either way thats just a master cylinder switch, or Id get the front hydraulic line switch. Front brakes are 70%
Edited by notoriousE-R-I-C
1989 US models have a front disc.
Did you read the starting post?????? he states DRUM brakes not disk??:banghead:
He knows. He is saying get a hydraulic line switch for the front disk.
It obviously isn't a hydraulic switch for the rear but there is a switcg. Hes saying use that or this. What Im saying is you use your fronts 70% you use your rear 30% best and first bet would be to get a FRONT, either hydraulic line switch or the master switch which its an R it might not have it but its an enduro. I had and right now have two Rs where the master has switches. So go spend $5 or if youre near San Diego Ill just give you one. I bet you could walk to the vack of a Honda and say psssst can I get one of these? Boom, under the table
Vic said exactly the right ish
That man knows what hes talking about
All good hope you got what you were looking for in all our dribble??? ha ha good luck with it all
