Part swap from 02 to 06
Hey all,
Getting an 06' tomorrow!!! So, question is I have an 02' decked out, can I swap the clark tank, rekluse clutch and warp 9 rims to the 06'?  Please say yes...
(Edit) After looking at some other posts it looks like the tank works and I'm pretty sure the wheels will work. So my main concern is the rekluse......
Thanks!!
Edited by cr250r_fun
Going by Honda Microfiche and doing a bit of cross-referencing 02 & 06 use exactly the same clutch parts.
Fuel tanks the same.
Front wheels are the same - collars, bearings, spacers etc....
Rear wheel the same - all the collars, bearings, spacers - hub is a different part number - but if all the spacers and that are the same it will fit.
Everything will bolt up as those parts are the same from 02-07.  The rear hub is the same dimension the difference is in 05-07 Honda went to a lighter & stronger rear hub.
Edited by H4L
