Piston and cylinder scuffs normal?
My bike (2016 YZ250X) now has 30 hours on it and I looked in the exhaust port and saw this.
We can see the cylinder having a vertical darker line at the left in the picture, and the piston has these small scuffs.
Is it a big problem? How is the health of my engine?
I always used Motul 800 2T with premium gas.
During the first 20 hours or so I runned 30:1 mix, after that 50:1 because it was smoking way too much.
I also leaned the bike the 48 pilot, 175 main, and played with different needles depending on temperature. Now running N3CW clip position 1. Sea level
The cylinder looks absoloutley perfect, and sure, you'll find a few scuffs here and there but it happens and its not like theyre bad enough to cause loss of compression, I'd just keep riding it if i were you
Hello Sebas,
50:1 is quite a departure from 32:1, if mostly off-roading at lower rpms & engine load that's no problem
but if you regularly ride MX style / wide open throttle then I feel you'd be stretching your luck a bit (I'm old school...)
Not 100% familiar with Motul products but if the 800 is a 'racing' (high flash point) premix,
it may not be the ideal choice for a trail ridden bike and prone to smoke/spooge no matter the ratio or jetting.
That being said, those scratches are not too bad but as a comparative
the used pistons I remove from my YZ125 after 20-25 hours look brand new compared to yours.
If those were on the intake side I'd blame dirt/debris injestion past the air filter,
out of curiosity pull the carb and reeds and have a look on the intake side.
Edited by mlatour
29 minutes ago, mlatour said:
Hello Sebas,
Yes the Motul 800 is a racing oil with high flash point so it might explain the smoke since I'm only trail riding (with frequent high rpm for 1-2 secs)
And also some high speed for a 1-2 km to get to the trail, but I do not stay pinned all the time, like, acceleration, coast(decel slowly), acceleration, etc..
On the bottle they recommend 50:1 for MX racing and 60:1 so I guess I'm am good at 50:1.
And when I was looking in the exhaust port, I could see a coating of oil on the piston as I was moving it with the kickstarter.
There is no spooge and with the jetting I'm using currently smoke is almost non-existant.
As mentioned Motul 800 has a very high flashpoint.
I use Motul 710 and ride quite hard mixing it 30:1 when mixing 50:1 my crank last 200 Hours with 30:1 my crank last so far 400 hours. Plus the ring will last longer.
