Mikuni BSR 36?
Can anyone explain this :( I bought a used carburettor for parts...
I had a problem in VALVE, PISTON 13501-29FA0 one out of four was cracked and did not hold well.
I bought the whole carburetor for $ 60. Brand new VALVE, PISTON 13501-29FA0 is $ 50 :(.
On the upper part of the carburetor "VALVE, PISTON" 13501-29FA0 there is no holder (SUZUKI 13418-33E00) (PICTURE 1.) and spring connecting to the NEEDLE JET only the metal part (PICTURE 2.) and the big spring connected to NEEDLE, JET .
I installed it in my carburettor and everything works well with no holders and litle springs.
Is this normal?
Edited by Patak
That big plastic thing isn't stock. There should be a large washer, then a plastic spacer, then the e clip, than a small washer. With the e clip being clipped on the needle. That also looks like the jd jet kit, high temp/high alt needle.
Not important for this potential problem. At the same time I installed the JD Jet Kit.
After installation, the engine/carburator is working well...
Edited by Patak
VALVE, PISTON 13501-29FA0 this is craked :( (Look the picture) and I instaled a used VALVE, PISTON whit only metal pic...
Just now, 74jimbo said:
Whit only metal pic?
What?
Because the used VALVE, PISTON 13501-29FA0 does not have four brackets inside  - see the picture only metal part..
