Mapping Switch
My 2017 390 RRS didn't come with a mapping switch, I now have the mapping switch and need to install the switch. Switch comes with a black wire with a male prong, the other wire is green with a ring connector.
My understanding is the black wire plugs into the female plug on a yellow wire with the red tracer, found in the wiring harness under the tank, I don't know where the green wire connects to.
Can someone confirm where these two wire go.
thanks
You're correct on the black wire with the bullet connector, the ring connector goes to ground which normally goes to the lower bolt on the coil.
