2016 Beta 300 crankshaft bearings
Shopping for parts for my 16' 300rr. Already had crankshaft rebuilt and trued by Cooksey. Shopping for crankshaft bearings and ProX only seems to have them listed from 13-15 and nothing for 2016. Are they the same? I compared the 15 to 16 parts breakdown but the numbers are changed but I've noticed that in other areas where it's just an updated part. Anyone have any insight? Thanks
Hey B300RE
For the crank bearings, simply search for bearing spec: 6206c3 - Purchase any high quality brand (timkin, KOYO, FAG, etc...)    I bought Koyo's at $12.00/each when I redid my 15 300RR. Just make sure you do not get the "Sealed" version of this bearing, you want the open bearings.
The exact bearing I put in my '15 300rr was: KOYO 6206C3 Open Deep Groove Ball Bearing 30x62x16mm
http://www.qualitybearingsonline.com/koyo-6206c3-deep-groove-bearing-30x62x16/
for the crank seal set, search for: crank seal 68-4486    -  this will match to KTM's 250/300 crank seal kit, should cost you around 15-16 $$
here is the set I used: http://www.ktm-parts.com/68-4486.html
cheers
-t
Edited by lodcomm
fix typo
  • Like 2
