Bike identification
I found a bike (frame, forks, mono, swing arm, wheels, but no engine) dumped on my road.  Since the VIN was ground off, I turned it over to the police and washed my hands of it.  6+ months pass and the cops call me asking if I want it back.  I took it figuring it'd be worth something.  How do I identify this without a VIN or distinguishable numbers?
I know this is a Honda; I think this is a CRF, but I am not completely sure.
Any help is appreciated.
Someone else can chime in but if the rear wheel is 19 inches it's an R. If it's 18 then an X.
There is NO VIN number on this frame - it was ground off when it was stolen.
I am located in Canonsburg, PA.
CRF250/450 and CR125/250 chassis look the same and share a lot of parts.
I see one clue and that is the case protector on the left side, check photos or part fiche to find that unique case protector.
There is a plastic ring around the fork clickers (in center of fork top) and if not too badly sun faded it indicates the model of the forks. Blue=450R, Red=450X, Green=250R, Black=250X
Rear wheel size is another indicator; 19 is "R", 18" is "X"
On the "X" the right fork guards have a clip riveted near the top to hold the speedo cable and the right side of the wheel has a speedo drive. The top triple also has brackets on the front side to hold the speedo and headlight shell.
Finally all three engines have different motor mounts.
I had both a 250 and 450 (2004) and I think the shock mount is different between the 2 and the frame is smaller. Yours looks more like the 450 I just sold (pulling the carb always meant disassembling everything including the upper shock mount). I could be completely wrong and it turns out to be a 1978 maico (but probably not)
The  "Y" is unique to the '02 - '03 CRF450R which has front engine mount brackets.  The '04 may have had those as well, I'll check.
EDIT:  Hard to tell by the fiche so someone will have to chime in on the '04.
Edited by HRC27
Definitely 02-04 450R - no kickstand bracket for an "X" - which first arrived in 05
Some awesome information for sure!
Based on the front shock color rings and the wheel sizes, I believe this to be a 450R.
Based on the triple mount, I think it must be an '04.
Thanks.  This at least gets me in the ballpark...
Shawn, it's important to read all the threads. The initial post says:
"I found a bike (frame, forks, mono, swing arm, wheels, but no engine) dumped on my road.  Since the VIN was ground off, I turned it over to the police and washed my hands of it.  6+ months pass and the cops call me asking if I want it back.  I took it figuring it'd be worth something."
Pretty sure that answers you question.
No worries, I missed that whole sentence. If you notice, Ive been around here a long, long time and I read A LOT of posts as it's kinda my job around here. Being a Mod and all.
Yeah i think we've all done it  :thumbsup:
13 hours ago, harmetp said:
No problem. In this case (maybe rare) the OP did all the right things as far as the cops were concerned.
Forgive me... what is "OP"?
