So i did replaced the top end in the spring on my 2001 cr250 the bike ran great after but last weekend i went to take it out and noticed it was sputtering after half throttle. Ive cleaned the carb set the float cleaned the filter checked the plug and even put a new plug in but nothing helped and it only got worse. Compression test came up at about 230psi. Im not sure what it could be so any help would be great.
Edited by bigroanslamrick
Plug cap?  Bad connection between the existing cap and coil wire (trim and reinstall it.)
I did check the plug gap which was good, i didnt check the wire or cap but i did check the spark which looked like it was getting a strong spark. Ill have to wait till i go up north it two weeks to check anything else. Trying to get an idea of what parts i should bring up with me to get her running good again.
