2001 cr 125 Idle issue HELP!!!!!
Hey, i just rebuild my bottom end, when I started my bike it freaking idles in the apex. I adjusted the idle srew and it did absolutely nothing, please help!!!!!:banghead: :banghead:
Edited by Nate.S
You could have a problem with the rebuild and have an air leak. Main seal , base  or reed gaskets. Or it could be something as simple like you pinched the throttle cable and the slide is not closing.
Thnx!!!! How much does the slide need to be open during Idle. By main seal do you mean the the fly wheel side crank bearing seal?? :thumbsup:
Or could it be the power valve????
Edited by Nate.S
