YZ250 copper crush washers on head but not the base studs?
On the YZ250 and I guess most other 2 strokes:
Why are there copper crush washers under the nuts on the head studs, but not on the cylinder base studs?
I guess it's to reduce the chance of coolant leaking past the head studs.
Thanks.
the base gasket seals the bottom, but the studs are exposed to the water jacket and need to be sealed externally.  If you had a head gasket rather than o rings, then you would not need copper sealing rings on the head.
