Leaky Beta petcock? - 3D Printable shim to correct
Hey folks,
for those of you with access to a 3d printer:  Here is a stl of a shim you can place behind the rubber gasket inside of your beta fuel petcock to stop the fuel from leaking by when you switch it to the off position.  I print them out of PLA which is resistant to gasoline & 2 cycle oil.
https://www.thingiverse.com/thing:2415224 - beta petcock gasket shim.
cheers
-t
Hey folks,
cheers
-t
sell em?
Do they leak all on their own, or this due to a varnish build up?
I can't get the link to work.
I love 3D-printing. I don't have my own machine, I just use Shapways.com
as fas as I can guess it is the ethanol in the gas that causes the gasket inside the petcock to deform/shrink - this shim just takes ip the slack and allows for the gasket to press tighter to the fuel passages.
Gotcha. Never had a Beta, but I have had other petcocks do this from old fuel/varnish.
Had that gasket go twice on my dry break tank, it only gets used a couple times a year, so it sits in gas for a week and then drys out for months, could also be the MXR02 fuel we we using, good idea to add a gasket to your spares box.
I have been unable to locate the gasket as a stand alone item? Thus I am forced to do the shim hack :)
Mine is leaking now. Anyone able to find the gasket or full petcock rebuild kit?
According to my dealer, they don't exist. However, he had a petcock from a Husqvarna that fit for only $22.
Thanks Sierra_rider. I actually took the petcock apart and the rubber looks fine, so I just gave the bends on the pressure washer a bit more angle and reassembled. It stopped leaking for now but I'll need to replace it soon.
