hey guys, I have a 2003 TTR 125R.  The throttle housing is cracked and needs to be replaced.  it is hard to find new aftermarket parts as well as pre used parts.  does anyone know if it has to be exact?  is there a substitute I could use instead?  also, anyone know of the best place to get aftermarket parts for an 2007 Apollo 160cc?
All these the same throttle housing
Assemblies where 434-26243-00-00 is used
1974 DT100A - Handle Wire
1974 DT175A - Handle - Wire
1974 DT250A - Handle Wire
1974 DT360A - Handle Wire
1974 YZ80A - Handle - Wire Yz80c
1975 DT100B - Handle Wire
1975 DT175B - Handle - Wire
1975 DT250B - Handle - Wire 250B - C - 400B - C
1975 DT400B - Handle - Wire 250B - C - 400B - C
1975 YZ80B - Handle - Wire Yz80c
1976 DT250C - Handle - Wire 250B - C - 400B - C
1976 DT400C - Handle - Wire 250B - C - 400B - C
1976 YZ80C - Handle - Wire Yz80c
1977 DT250D - Handle - Wire
1977 DT400D - Handle - Wire
1977 YZ80D - Handle Wire Yz80d
1977 YZ80D - Handle Wire Yz80e
1977 YZ80D - Handle Wire Yz80f
1978 DT125E - Handle-Wire
1978 DT175E - Handle - Wire
1978 DT250E - Handle Wire
1978 DT400E - Handle Wire
1978 YZ80E - Handle Wire Yz80d
1978 YZ80E - Handle Wire Yz80e
1978 YZ80E - Handle Wire Yz80f
1979 DT125F - Handlebar Cable
1979 DT175F - Handlebar - Cable
1979 DT250F - Steering Handle - Cable
1979 MX175F - Handle-Wire
1979 YZ80F - Handle Wire Yz80d
1979 YZ80F - Handle Wire Yz80e
1979 YZ80F - Handle Wire Yz80f
1980 DT125G - Handlebar Cable
1980 DT175G - Handlebar - Cable
1980 MX175G - Handlebar-Cable
1980 MX80G - Handlebar-Cable
1980 YZ50G - Handlebar - Cable
1980 YZ80G - Handlebar Cable Yz80g
1981 DT125H - Handlebar-Cable
1981 DT175H - Handlebar - Cable
1981 MX175H - Handlebar - Cable
1981 YZ60H - Handlebar - Cable - Yz60h
1981 YZ80H - Handlebar Cable Yz80g
1982 XT125J - Handlebar - Cable
1982 XT200J - Handlebar Cable
1982 YZ60J - Handlebar - Cable - Yz60h
1982 YZ80J - Handlebar Cable Yz80g
1983 RX50K - Handlebar - Cable
1983 XT200K - Handlebar - Cable Xt200k - Kc
1983 XT200KC - Handlebar - Cable Xt200k - Kc
1983 YZ60K - Handlebar - Cable - Yz60h
1984 RX50L - Handlebar - Cable
1985 BW200N - Handlebar - Cable
1986 BIG WHEEL (BW200S) - Handlebar - Cable
1990 RT100A - Handlebar - Cable
1992 RT100D - Handlebar-Cable
1993 RT100E - Handlebar-Cable
1994 RT100F - Handlebar - Cable
1995 RT100G - Steering Handle - Cable
1995 RT180G - Steering Handle - Cable
1996 RT100H - Steering Handle - Cable
1996 RT180H - Steering Handle - Cable
1997 RT100J - Steering Handle Cable
1997 RT180J - Steering Handle Cable
1998 RT100K - Steering Handle Cable
1998 (null) (RT180K) - Steering Handle - Cable
1999 RT100L - Steering Handle Cable
2000 RT100 (RT100M) - Steering Handle - Cable
2000 TTR125 (TTR125M) - Steering Handle Cable
2000 TTR125 (TTR125MC) - Steering Handle Cable
2000 TTR125L (TTR125LM) - Steering Handle Cable
2001 TTR125 (TTR125N) - Steering Handle Cable
2001 TTR125L (TTR125LN) - Steering Handle Cable
2002 TTR125 (TTR125P) - Steering Handle Cable
2002 TTR125_L (TTR125LP) - Steering Handle Cable
2003 TTR125 (TTR125R) - Steering Handle Cable
2003 TTR125E_LE (TTR125ER) - Steering Handle Cable
2003 TTR125L (TTR125LR) - Steering Handle Cable
2003 TTR125LE (TTR125LER) - Steering Handle Cable
2004 TT-R125E (TTR125LES) - Steering Handle Cable
2004 TTR125E_LE (TTR125ES) - Steering Handle Cable
2004 TTR125_L (TTR125LS) - Steering Handle Cable
2004 TTR125_L (TTR125S) - Steering Handle Cable
  • Like 2
At Partzilla, the 2003 thottle tube is $20.75, but the 2005-2007 is $2.24.  So try that.
I was just thinking the same thing. Even the brand new TTR shares a lot of parts with the older models.
