08 crf450x lighting questions
I am converting an 08 crf450x to a street legal dual sport bike.  I decided to leave the stock lighting (headlight and tail light) as is.  But, I would like to use the head light switch in the dual sport switch I installed to turn the headlight and tail light on and off.  Can anyone tell me what 12v+ wire (and where it is located) feeds both of the lights.  I could break into it and add the switch.
Also, I built a total separate wiring harness (fused at the battery) for the horn and blinkers.  I'm also adding a brake pressure switch to run a newly installed brake light.  The blinkers are LEDs, and the horn is small, so I'm guessing with very little intermittent use, the electrical system on the 450x will handle this additional small duty....right?
Thanks for reading this post and for any information you can help me with.
