DRZ 400 cranks but won't start
That's the piston moving up/down and why they need a breather. You'll need to do something with the carb to get it to run , I doubt it was completely cleaned . Likely the pilot circuit was not unplugged.
Since you have the fcr , give the bike 4-5 throttle twists to squirt some fuel down it's throat . see if it'll pop off . If it doesn't take out the plug and see if it's wet . If wet try holding the throttle open 1/8 turn while cranking and every once in a while give it a accel pump squirt .
That video didn't have you splitting the carb in half did it ? I'd hope they just had you take the bowl of and take the jets out ect.. but not total teardown , the fcr is one that doesn't take too nicely when taken completely apart without complete new seals and gaskets , even then .
The carbon on the valve(s) is common as long as it's just barely enough to "look" like it has some on it , but not a thick coating .
Well guys I apologize for the long absence.  Like i said I've been working at this when i get time and the past few days I've been hard at it again.  I built my self a little homemade cylinder leak down tester with the hose from my compression tester with the schrader valve removed and an air compressor with a rubber tip on the air chuck. i was able to fashion some that was air tight and i could use to pressurize the cylinder.  I found that with the engine at TDC and the cylinder pressurized, I have air pushing back through my carb.  Its a substantial amount, enough that i can feel it on my hand when i put it up to the carb throat.
Am i right in assuming that i have a valve problem?
Im thinking my next step is to pull the head and inspect the valves to look for a bent or burnt valve.
Any thoughts?
Any thoughts?
Are you sure it's on the compression stroke?
Sent from my SM-G930V using ThumperTalk mobile app
Ok. I'll do that tomorrow. I assumed that regardless of the stroke the valves would be closed at TDC.
To do the leak down properly you will need to disable the decomp. This requires the valve cover to be off anyway. Otherwise, you will be losing air out the right exhaust valve. You will probably be able to figure this out by yourself but let me know if you need more guidance.
So I took the cams completely out of the head to eliminate any possibility of valves being open and found that my intake valves are not seating properly and blowing quite a bit of air by them. They look extremely burnt and carbon coated. I pulled the head assuming this is probably my problem.
I'm kind of at a loss for how that could be the issue if you truly have 120 psi of compression with the decomp active.
Flip the head upside down on the work bench and puddle some solvent on the valves. Look for where the solvent leaks past the valves to confirm the issue.
Don't lose the cam dowels when flipping it over.
I'll give it a try. Hopefully that will give me a better idea.
They just seem like the seats are not clean enough to seal. The compression spec is over 140psi for this bike I believe.
If this isn't my whole problem, then it's at least contributing to it.
The manual states 130 psi with decomp active.
Sent from my XT1650 using ThumperTalk mobile app
That what I though , 120 may not be tip-top but should be plenty to run . I'd expect down in the 80-90'ish range to start having starting issues . Fresh rebuilt motors with rings not yet seated-in are in the 110-130psi range without a decomp and they start .
Edited by jjktmrider
If you plan on keeping the bike it wouldn't hurt to rebuild the head. It is nearly 15 years old.
Beyond that, a factory service manual goes a long way. I still suspect a carburetor issue but my magic 8 ball isn't always right. There is always the dealer option if you can't figure it out.
My plan was to overhaul the head since it's already off. The bike is clean enough that it's worth holding on to and eventually I'll sort this thing out. The carb issue is still in the back of my mind. I'm still not totally educated on this vacuum stuff. I understand the basics of it but I don't fully understand how it works and I feel like I could have a problem there.
The manual is shipped already. Should be here Monday.
If all else fails I might have to go the dealer route as much as it pains me to do it.
