Engine Primer
Restoring an 88 RM250 and had the engine soda blasted to bare metal. Today I sprayed some Rustoleum self etching primer on the engine before using the VHT Engine Enamel paint. The primer looks kind of "soft" to me. I don't know whether that's due to it not being fully cured yet or not. I can easily run a finger nail through to the bare metal.
Will this cure to a more scratch resistant finish after a few days? I'm hoping I didn't make a mistake using this primer but the blaster recommended it be done before the paint was applied.
Thoughts?
Is this primer rated for high temperatures? If it is rated for the same hi-temp use as the VHT, I wouldn't worry too much. One thing I would worry about is drying time and recommended time lapse before another coat can be applied. I've been burned real bad with paint turning to a stucco like finish because I didn't wait long enough for the primer to dry.
