Prox steering bearing seals question
Hey guys,
Anyone used the steering bearing kit from prox? I bought it to replace my old ones but I got 3 seals in the kit and I don't know where I should put the 3rd?
It's 1 of the big one that goes on top and 2 of the other one which goes on the bottom. Anyone have any ideas where to put the 2nd or should I just toss it away?
Thanks
Kit is for steel frame and aluminum. The two that are almost identical are for the aluminum frame or "other model". Only two required, carry on.
Edited by P84ONE
What do you mean? I have the alu frame but I don't see how I can use both of the identical ones. They are the same part nr btw so 100% the same.
I think the bearings are the same on the early steel and later aluminium frames. The bottom seal is the same but the top seal is different? If I am wrong some one chime in.
It's cheaper for them to produce one kit to cover '96? to '17? and for you to bin one seal. Than to package, market, stock two kits. One for steel one for ali frames.
1 seal on top, 1 seal on bottom, 1 seal in trash or give to a friend with a steel frame. Carry on.
See my comment "other model".
Edited by P84ONE
Assuming you are talking yz125 / 250
Aha that was what I suspected but thought maybe it was some kind of upgrade or something. Thanks
Great, thank you!
Yeah it is a 2010 yz250 getting a full rebuild since last owner neglected it badly.
  • Like 2
Good luck with the rebuild!
Thanks for coming back and letting us know you have got it figured out.
Thanks bro, always so nice and knowledgeable people on TT. 😃
