Snapped upper chain roller bolt on pit bike
Any ideas how to get bolt of this under swingarm this is my first bike and only. Learning thanks any help would be great and is my bike sitting to high still changing front wheel to 14inch received_1409644055793541.jpeg greatfullreceived_1411823602242253.jpeg
If you're refering to the swingarm pivor bolt itself, you need to remove the broken part so you can soak the rest of it with PB Blaster penetrating oil after tipping the bike over on its side. Then you need a long drift punch and a good-sized mallet to drive out the rest of the bolt.
The bolt under swingarm for chain tenesetion snapped its not on the swingarm thanks anyway
2 minutes ago, dirtbkr188 said:
Cut the old bolt off flush with the frame and then drill a hole to bolt the one linked below to the frame.
Chain Tensioner
Thanks for the help will give it go
