Difference between swing arm and linkage bearing kits?
Got an 87 yz250, doing the swing bearings, order the bearing kit but i noticed the shock linkage bushings are also wore. Im finding swingarm linkage kits all over but they are misleading imo. Will the swing arm bearing kit come with the linkage kit too? Getting a pivot works bearing kit.. Just wanna have all the parts at once, thanks.
The lower shock bearing will also be separate from either kit.
Sometimes just buying the OEM bearing you need is much cheaper than a whole kit.
So just curious does anyone know how to get the bushings where the linkage connects to the swingarm out?
