[S] Blank screen on dash
Hey guys! So I cleaned my bike earlier, got it all shiny which is good, but when I turned it back on the dash shows nothing, just a back-lit screen. No time, no speed, just an orange glow.
I'm thinking maybe one of the wires got disconnected when I was cleaning it as it was wiggling around a bit when I was wiping the screen. Another possibility is water damage, but would that happen? I'd imagine it's water-proof.
The back side of the housing crack pretty easy mine is from a light drop maybe have a closer look just pull the headlight shroud off
Re,move the speedo. CAREFULLY, remove the back, let it dry out for a few days in the sun. Re-connect and see if it comes back. If it does, reassemble and seal and be more careful with the wash down. Consider a cheap replacement like a Trail Tech Vapor.
It seems like it just needed to dry out! Left it off for a few days while I what doing maintenance, worked next time I turned it on!
