ktm 450 SXF 2016-2018 48nm (Whats your preload and static sag?)
Hey,
Got some variations in my sag (7mm preload gives me sometime 34-35mm static, sometime 42mm), i think i found the issue (possible loose rear frame mounts/bolts). Running stock 48 gearing now, with maybe some mm extra tension on chain.
At 7mm preload (spring is ~247mm, mine is compressed to 240) i get 34-35mm static. I have as mentioned gotten weird numbers like 42mm for the last 2 weeks until i fixed rear frame bolts yesterday.
Do you get similar numbers?
Which bolts are you talking about? Sub frame bolts? I have 42mm static also. I'll go see if I have anything loose and then remeasure....
Yes subframe bolts, upper mount under tank.
