EXCF 250, question after oil change!
Quick question, changed the oil on my excf 250 today, first change as haven't had bike long, all went smooth and did as per manual said, however I don't think the manual is clear about oil levels, so can someone tell me if this is the correct level, (picture below)
i filled the oil filter up and housing quarter way full, all together I put in 1050 ML of oil, manual stats 1100ml
this is the level after the engine has been shut off around 90 minutes, im slightly worried its over filled, or will it be okay?
thanks
Edited by Ralph
its fine, I run it that way all the time, some times higher.
as long as its upright, if that's sitting on the side stand then yeah too much
Edited by Spud786
  • Like 2
Thanks for reply, yes that's with it upright, cheers for info I'll know for next time now that it should be that level 👍🏻
