advice kx450f
would u be able to hear if ur cam chain tensioner is on its way out or chain has stretched to much because when i go to up it i hear a rattle but its only for a second can't hear a it till u slow down then take off again its pretty loud sounds like the chain slaping
I just replaced my cam chain on my bike there a thread lingering around with some before and after vids I posted. It's not your chain guide making the noise on your swingarm by chance is it?
it might b it only happens when low revs an i take off u only hear it for a split second then when its in neutral it doesn't do it so that was my second thought might have a look at the chain maybe it needs to b adjusted
Sent from my SM-G955F using ThumperTalk mobile app
Sounds like the chain running on the swing arm. Look at the top of swing arm behind the slider. Should see chain wear imdictations.
