So I bought this bike about 2 months ago .. noticed a small leak where the exhaust manifold and expansion chamber meet the head mounting studs.. seems to progressively get worse as I ride as I notice more smoke. so I pulled off my pro circuit pipe and my exhaust manifold and I noticed the top stud is super stripped (the nut just keeps spinning on the stud). I am wondering how I can get this stud out because it seems to just be a stripped stud and it will not just turn out with vice grips.. and are there any recomended studs or sealers I can use ?  Also how am I going to screw in the new stud without damaging the threads ? As you can see I don't have enough room to put 2 nuts on and screw it out as I tried that ! IMG_0613.thumb.JPG.2ebd07ec7b319e0a56812e595adbe377.JPGIMG_0665.thumb.JPG.a1ac7752c801ddd501795f918c3e6264.JPGIMG_0666.thumb.JPG.9d679bbb3546e8b14f5e54de513d7b1b.JPG
Try a pipe wrench first, looks like your not going to hurt it even worse.
Next your only option is to weld a nut on the end and unscrew.
Weld a nut on the stud and it will come straight out.
I think there maybe a crack in the casting just above the stub if my eyes are functioning correctly so more work may be called for.
  • Like 2
The current stud is set too deep, yes, it looks like a crack is starting. New stud should be double nutted, have red loctite applied and screwed in snug (not cranked down, torqued correctly).
A tool like this removes studs best:
https://www.grainger.com/product/36T851&AL!2966!3!166594882706!!!g!71849891719!?gclid=CLHnpIWIkdUCFY1LDQod9pkJHQ&cm_mmc=PPC:+Google+PLA?campaignid=719691813&s_kwcid=AL!2966!3!166594882706!!!!71849891719!&ef_id=WPzEwAAABXqLcfAq:20170717193534:s
Also at amazon:
https://www.amazon.com/Stanley-Proto-Facom-FA-287B-6-Extractor/dp/B002FCJCVE
  • Like 2
Ok thanks guys.. first dirtbike I've really been getting dirty with I really want to know it inside and out and also see what previous owner has done... since the stud is bad I'm going to try a small pipe wrench.. if all else fails it's a good thing I'm a welder lol I'll just weld a nut on ... also didn't even notice that crack wow ! Looks like more inspecting will be done when I get home tomorrow from work. Will stay posted ! Btw thanks for the suggestions
I highly agree with what has been mentioned already. Using a pipe wrench may cause more damage, but welding a bolt on that stud right quick will be the easiest way out without doing more damage.
Ok well bad news is pipe wrench does not fit where I can even get a decent turn .. also was going to slot it but I can't find my Dremel.. so looks like she's coming into work with me going to weld on a nut ! But that definitely is a crack in the casting ..:( wondering if she's scrap or salvageable ?
18 hours ago, cjjeepercreeper said:
I use a puller that looks like this:
Those work pretty good, the only downside is the rotational force is not centered on the stud. A stuck stud and a crack like the OP has and that tool might make matters worse. They work great for regular, undamaged stud removal. The only issue with the tool I referenced is it has a narrow operating range so to cover most sizes you need a set and that gets pricey.
Well I went old school and welded nuts on two of them and they came right out ! Third one I actually got with vice grips. Now I'm just wondering what to do with this small crack I found in the casting ??
If it were my bike I would leave the crack alone, I would run a bottoming tap in that hole to make sure its al clean and tapped to the bottom and make a new stud that will most likely be a 3 - 4 mm longer than what came out to ease the load on that area and I very much doubt if it will ever grow or cause any problems ,
Im sure plenty will say get it welded but I have seen way way worse in my time that have never caused any problems.
@johnnyboy okay definitely will run a tap through all three holes and Im going to weld it .. might aswel since I'm a welder and I can bring it into my work! Just gotta figure out exactly what metal it is .. research time
I would just use the same torque as the nuts are spec'd.
87 in/lbs on mine.
Edited by wielywilly-g
Pretty much any aluminum filler should work.  You could probably just go across it with a tig without any filler and call it good.
in my experience most aluminum castings are a high magnesium alloy but really  I don't think it matters all that much.
btw, I know this is too late but welding a nut on is the best approach.  some of the heat from the welding will seep into the case and make the stud come out easier.
