Cleaned carb DR250 and small jet in float bowl IDK what its for? 1990
Tube is clear. Now does it actually seal? I doubt it so could be causing flooding.
Okay,
Near as I can tell there should be only one o-ring and one gasket involved in the fuel enhancement circuit, along with the passageway drilled in the carb.  Behind the "choke" knob should be a hex fitting which is securing the enrichment plunger to the carb.  Behind this is where the gasket could be leaking.  The o-ring is at the end of the plunger passage and actually seals off the fuel flow when the plunger is pushed in.  I tried to attachthe DR-350SE Shop Manual for illustration.  I don't know how well this will translate to the DR-250.  Look here.
Suzuki DR350 motorcycles, 1990 - 1999.
Featured topics
Spare parts catalogs / exploded parts diagrams / parts fiche
Workshop manuals / shop manuals / service manuals
Almost done putting it back together but I am not sure I can get the plunger to seal on the carb without some sealant or something so think I will get some silicone grease (solid, not spray).
I was unable to get a wire to go thru one of the front jets.  I can get carb cleaner to spray thru it and I can catch the hole in the main jet tube but I wonder if the main jet tube is twisted slightly so the hole does not line up.  There is also a hole on the intake side that may just be a dummy hole that is used for 350 or other bike but I cannot trace it with a wire either.
Along with that I am not clear as to what the hoses coming off the carb do or where they go.
Front right is plugged. I will redo the plug I made.
Rear right goes up into frame. For oil pressure?
Tiny bottom just seams to be a drain?
Edited by aviator79
On 9/30/2017 at 1:35 AM, aviator79 said:
Still not sure if this jet is working right but cannot remove so we will see...
Quote
This is a vac port that would go to vac port on Petcock if you had one.
This port is some vac release hose and mine hose was clogged which was probably part of my issue
http://advrider.com/index.php?threads/dr350-thread.230695/page-14#post-5864925
Quote
This hose needs to be clear as a vent for bowl.  Mine was clear.
I sealed this with permatex #2 form a gasket.
Quote
I am still not clear on these ports/jets.
Edited by aviator79
Also the o-ring that I got from here 13374-46710
http://www.thisoldtractor.com/for_sale_dr350_orings.html
for the float cage was too large and would not seat.  This could have been another issue.
I replaced it with the one that came in the kit I bought and it seated properly
K&L Economy Carburetor Rebuild Kit #18-9310 Suzuki $23.63 shipped
I also replaced the float valve, float valve seat w oring and float bowl gasket with what came in that kit.
I am missing one seal 13556-44B00 that goes on both sides of the throttle shaft
#14:
https://www.cmsnl.com/suzuki-dr250se-1990-l-usa-e03_model15951/partslist/BLCK0009.html#results
It is basically a felt seal to block air and debris.  I put on oring on shaft and filled with grease so hopefully will work without it for now.
Now to install and see if runs...
Edited by aviator79
