2014 Piston Failure - Need Advice
Failure at 10 hrs.   Hit valves, bent crank, ruined cylinder.   I need:
gaskets
pistons and rings and wristpin, etc
Valves
Crank
Cylinder
What should I do?  $2K in parts.  Fix it.  Can I buy a whole engine?  Part it?  What would you do?
Complete engine i see on ebay is going for about $2k US in London Kentucky - not far from you.
I would rebuild. Send the head in and see if you can buy a complete kit with crank piston and gaskets. I believe wrench rabbit would have everything. That way you know what you have instead of starting with a used motor for 2 grand. Put 1500 into yours and make it like new again.
I found a wrench rabbit bottom kit for a 2013.  I think it will fit a 2014.  Just wanted to be sure.
I would call wrench rabbit too be sure. They are very helpful over the phone and can answer that for you
