Help with clutch push rod and slave cylinder
So I had to work on my 2005 Husqvarna tc250 clutch... While the clutch components and clutch push rod were out, the clutch lever got pulled in.  When I put everything back together, the clutch push rod doesn't go in all the way. It's about 5-7mm out.  Does this mean that the clutch slave cylinder piston came out and now won't allow the pushrod back in?  If so, what do I do?  Do I have to take the slave cylinder off and push the piston back in?  Or will the pushrod get pushed back in if I try to finish putting on the pressure plate and springs?
Thanks
Thanks.  I took the slave cylinder off and then reassembled the clutch and pushrod and then put the slave cylinder back on. I think I'm all good, but haven't gotten a chance to test it but the clutch seems to be working.
