plastic/silicon in carburetor ??
I have a yz250f that turns off with any gas but it idles, I opened the carb and found some plastic substance clogging the gas filter it works fine now but does anyone know why this happened ? so i can fix or prevent the problem. thanks.
14 hours ago, vicxr400 said:
more info and maybe a pic would help???
i already took all the plastic out and put the carb back
11 hours ago, cjjeepercreeper said:
Common cause is the rubber in the petcock disintegrating.
so i could buy another petcock and fix the problem?
10 hours ago, Still Bill said:
There is a filter inside the carb?
yes in the fuel reservoir
If in fact that is what is happening.  Take your petcock apart if it can be disassembled and see if the rubber gasket is disintegrating.
i will thanks alot
