HELP: 2016 CRF450R- Does not idle
2016 CRF450R- 70 hours did a top end and after putting it back together it doesnt idle.
As i try to adjust the idle when warmed up it either dies or idles at 3.3k.
I made sure the timing chain was correct, checked all connections, bike is clean, swapped out TPS, IAC, swapped tank( with fuel pump),  Remapped and nothing.
thanks
3 hours ago, Eddie8v said:
Timing off 1 tooth
First thing Id check too. Id bet it's one to the retard. Which means your cam chain tensioner failed allowing the chain to slip, then it reset itself.
