What size piston for a yz125
I picked up a nice cylinder that has crosshatching and doesn't have much wear and it doesn't have a stamp on it so I was wondering if I could put a 54 mm piston in it
Measure the bore, then you will know.
I don't have a guage and it's a 2005 so could I run anything between 53.95-54 and be ok?
Best get a gauge, mic bore. You can rent from an auto parts house.
Best to have a manual, and tools to perform any work. You will need a torque wrench also to put it back together.
You will need to measure ring gap and need a feeler gauge also.
So, to simply say, I could run anything between XXX-XXX and be ok, I can't answer.
Maybe someone else on here will give you an answer. So hang loose, and wait.
He said stock bore so I'm guessing a 54 will work
Buddy, you are missing the point. "Stock bore" is 4 sizes. If the engine has an A size piston coming out, and you put in a D size piston you might be 2 big and as it expands it will lock. On the other hand, if it is a D size piston coming out, and you put a A piston in, you will possibly have piston slap and wear the skirts prematurely.
An answer to get you a piston today: Vertex piston size B would/could/"B" a size that would work for you.
Pull out the piston, take it to an auto house parts store, and ask them to mic it.
But I would measure before you buy.
  • Like 2
I agree - except, to be clear, measure the cylinder.
There was a recent thread about this. Without open that can of worms again, the Engineers who designed the engine and wrote the manual say measure the cylinder and use the matching piston.
I take my cylinder into the shop to get it measured. Then I order the piston from the shop so he makes some money and hopefully is still around next time i need something like that done.
You can do it yourself with the correct equipment and skills, but the average person with borrowed tools wont get it right.
Yah, I ment to say "Cylinder" as his first post had said he got a new one with cross hatching and needed a size.
Thanks for the catch!
