2016 250f brake problem
Lost all pressure in my rear brake caliper at the track. Tried bleeding and reverse bleeding them with no luck. Piston is not stuck and I can't find any leaks. I have a race tomorrow so I need to find a solution. Any advise would be appreciated.
15 minutes ago, Monk said:
Did you book the fluid prior to losing pressure?
Not sure what you mean by book the fluid? Can you explain
He means cook. Check the banjo bolts and make sure the line is not cut or cracked.
Pull the master apart and see if there is an issue inside.
Did the bike get flipped upside down or did the calipe, line or master take a hit?
Which pads are you using ?
