How tight? Wire FCR Mod
How tight does the wire need to be on the FCR MX spring? I just did the mod and put the wire instead of the oring. I tightened it on there so when the throttle is open the arm still moves away from the spring but not as fast. Is that the point? Or am I trying to tighten it even more so they barely separate. I need to do a full test drive but I just started the bike and it still has the bog but it seems a little better. I just want to confirm that I have the wire correct.
