More power for my cr250
Hello everyone, i was wondering if there is anything i can do to make a little more power. It has a pro circut exhaust and silencer on it and is jetted for them. Any thing i can do to make a little more power? The bike is a 96 cr250 2 stroke.
Sent from my LG-LS997 using ThumperTalk mobile app
First thing would be a fresh top end and making sure the engine is within specs. (cylinder in good shape, no air leaks etc.)
second would be to fine tune the jetting, most will run richer than ideal 'just to be safe' but leave a lot of potential power behind.
A lot of 2T engines can benefit from measuring and correcting the compression squish band height,
allows leaner jetting for crisper throttle response but without the risk of detonation.
Off engine topic but very much related,
most rather mod the engine in search of better straightaway speeds but refuse to service and tune their suspension
which plays a major role in putting the power down sooner rather than playing catch up down the straights.
Edited by mlatour
  • Like 3
Twist the throttle and shift :thumbsup: yours may be tierd out cause that's actually a very fast 250. Atleast mine is :ride:
7 hours ago, YHGEORGE said:
Get in shape and practice. You can't use what you already have.
So you're saying he's fat and slow, without knowing him? Nice!:thumbsup:
You interpretation is quite flawed.
might not be fat and might not be slow, but probably doesn't ride his bike to its full potential and isn't at the highest peak in physical shape.
A friend I raced with back in the 90's had a 96.  He had a local tuner do some work.  The tuner shaved the head .020" & he raised the exhaust port 1mm if I recall.  It ran pretty strong with a fresh topend jetted to higher octane.  This was with a PC exhaust 13/50 gearing set up for MX use.
  • Like 2
Sounds like one i got but got boyeson rad valve.  I use to race some badass yz250's.  and honestly this engine is as good if not better. Rips :thumbsup: justtwist throttle and shift
Which of us on this forum are riding our bikes to their potential or are in top physical shape? If that's the criteria, we can ignore nearly all performance improvement questions.
Use to and almost be :ride: but few years off racing and almost 40 . Not so much anymore lol planning on making return for +40A :rolleyes: was tough racing 250 twostrokes against feild of 450s had to be in super shape
  • Like 2
That's great! Some of us never were super fast and simply like improving our bikes whether we can use it or not.:ride:
didn't say everyone else on the forum is, the bike is most likely fast enough in stock form, having the muscle and strength to handle it will make it that much faster.
Totally understand that but honestly engine work really isn't needed they are fast enough.  Get it set up so you're confident on it is much better.  A fresh engine and some good jetting goes long way.
engine mods can make them easier to ride even if you are not talented enough to use everything it's got. Depends on how it's being modded. After riding CR500s a fair bit I can't say as I've ridden a 250 that's too fast.... I have some pretty serious motors.
Ya same here then I got a feuly 450 :ride:
