Rear swing arm compatibility
So what I am trying to do is replace my broken rear swing arm on my 2014 Suzuki drz400s I'm looking into the used market what is compatible are the SM or the E the same did they change the S over the years what are the differences thanks for the help
If u change to an SM swinger (lol) the rear brake setup is different so you would need to look into that aspect. While the E model setup is close to your S setup (brake wise) it has no chain guard mount.
  • Like 2
Are all the s the same for the years
Interesting to know................:thumbsup:
Yes. If they aren't identical, there are no significant changes and all year S swingarm will bolt right up.
I would like to See a pic posted of the broken one. Cause of failure?
This is what broke the stud that got pushed over the and now I can't adjust my chain and the chain guard mounts got ripped off last year that's a good story for another time
A good welder could easily fix that for you. They typically charge $80 an hour with a $20 minimum. Probably would only cost you the minimum and wouldn't even have to remove it from the bike.
I have a welding shop I use but for aluminum it would be around $100 I just bought a new used one for $50 shipped the shop I use is a miracle worker with aluminum I can weld anything else
