ttr225 TTR 225 Front Fork Seals and Rear Shock Spring
This 2003 bike has the factory set-up and I need to replace the front fork seals.  From what I see in the service manual I need a special wrench to hold the damper rod in order to remove the damper rod bolt.  I see Bikemaster makes tools for suspension.  Does anyone know which tool should be used, or if there is another way to hold the rod to remove the bolt?
Also, is there a higher rate spring that I can buy for the front forks and the rear shock?
 You can try an impact wrench while holding the fork extended instead, of the holder, it usually works.
After doing the replacement work how do you torque the bolt without holding the rod?  I have never taken a fork apart and I am getting my guidance from the factory service manual.
