XR250 shock pressure
Attached is a couple of snaps of the shock from my 1991 xr250. There doesn't appear to be a valve for recharging the nitrogen. Does this type not have it or does it come apart further ?
thanks - it is so cruddy it looked like 1 piece.
can the pressure be tested to see if it needs repressurising ?
Yeah, you have to find a shop that does nitrogen. It's like a near inert gas is why they use it I guess (well the temp to actually heat it is way outside the operating temps you would see on a shock or a tire).
you need a NO LOSS chuck to check pressure, the volume is so low if you put a standard tire pressure gauge on it you will lose a significant amount of nitrogen and be starting over after a recharge.
yeah that is what i gathered. so seeing as it seems to have loads of damping on the bench, i'm going to put it on the bike and see how it feels. i have no ideas what rider weight it is sprung for either, the springs says 211 hand written on it. that i guess is 211 pounds as thats how we measure springs here, but 211 seems like an odd number, more the result of a test than manufactured.
