Back in the Saddle .... Almost
Alrighty then !! After a 5 year hiatus from the XR world I made a trade last night of a '01 CR125 to an '02 XR250
I think it's a fair trade considering it needs a new back tire and a carb clean ! Lol
After hitting the trails with my son (who is learning to ride) the little CR just didn't like going slow, so onto Craigslist it went. Within 2 days I found this guy who wanted to trade, and here I am !! I came from riding an XR650L and loved it but she was just a little too bulky for tight trails, that's why I got the featherweight 125. Well that itch is scratched now and I'm back on a ride with a kickstand! Lol
That's my boys XR 200 beside it.
  • Like 2
First off clean the Carb, next the tires then I'm going to ride the crap out of her ! Lol
Down the road I'll put an FMF pipe and re-jet, but for now I want to get my boy a little more sure footed on his XR200
I'm sure it'll need brakes and  I think I saw the fork seal was leaking, other than that it'll get new grips and peel of the numbers
Does anyone know what LED will replace the headlight?
@4runnerman88 - You are really going to enjoy slogging around the trails on your XR400. What tires are you going to swap in?
Here is a thread that I started on headlights.
I'll look at the link you posted on the LED
Ive been a fan of the Kenda K760 on front and rear, that's what I've run on the last few bikes I've had minus my 650L (I had the Terraflex 150/80-18 on her)
This 250 I just got will get the same tires just for reasons of durability and price along with good all around performance, good in sand, dirt and hard pack clay.
go through all of the pivot points on the rear suspension- shock pivots, linkage, and swingarm. They are usually neglected and if you wait until the swingarm bearings rust to the shaft, you will be cutting that bolt out.
As soon as I get back home from a short vacation I'll set into her and see all of what's up, and I can give a much clearer picture of what's going on.
Just read through the 400 Swingarm thread. When I had my 650L I would grease mine when I changed the tire, which was about every 1.5 years.
We ride enough wet conditions here with deep water crossings that I need to do all our bikes every winter.
  • Like 2
Well I'm feeling a little screwed at the moment.
I got back from vacation and started screwing with the new 250
I cleaned the carb, checked for spark, oil level was good, kicked till my leg hurt... nothing.
Checked the valve clearance which led me to this, the T mark and the valves don't line up. When I'm on T the Ex valves are starting to open (not right?) so timing must be off. When I turn the crank CCW about a 32nd of a turn it feels like the piston actually hits TDC and all 4 valves have clearance. What's the chance of this ?
I'm a little pissed at the moment, and kinda unsure what to do next. I'm going to pull the clutch side cover and clean out the oil because it was brown when I pulled the filter
Suggestions anyone????
