TDC timing on 2015 husqvarna 250
Doing the top end on my buddies 2015 250 husky and can't seem to find any marks on the cam, head or even a mark on the crank. we have a service manual but it only shows specs for clearance and no pictures of timing marks. any help would be great,TIA.
if its anything like the ktm 350 - on the bottom of the case there is a bolt with a thick washer - that will lock the crank at TDC once once you take off the washer and place the bolt back into place near tdc - pin as a taper on it to help located when your off a little- the cams have flat on them and the bridge has 2 dots on each side
