2006 KTM PDS shim stack help
I bought a used 2006 KTM 200 xcw. It was lowered with a spacer lowering kit so took it apart to remove it and due to a series of silly moves I ended up dumping the shim stacks on my bench.
Does this look right?
Also the pictures I saw online show the bottom washer as flat but my bottom spacer looks different. I removed a 1/3 inch spacer that was of machined aluminum.79662ab8ec82a3d281609e451057c07e.jpgd40033ad3a6fb2da497a756ff9bb92cc.jpg519a66c980074accd7dabab0c5ab3ebe.jpg
Your stacks "looks good" but you should post shim's OD and thickness to have an accurate answer. For the lowering, I personally prefer these KTM years lower. I feel the rear to high in the standard mode and I'm thinking that's the reason some were using crazy sag numbers as 45 free and 135 rider sag...
I still have a 250 XCW 2007 with a 5 mm spacer. Sag # are around 30/110.
I wonder if the bottom "washer" on the stack is a machined cone spacer to take some ride height out? I'm going to leave it in and see how I like it.
I pulled 1.5" spacers out of the front forks. They used 485mm springs which ended up having lots of preload.
