How to stop the silencer from leaking
Okay. I don't know what brand silencer you have etc but i do know some have allen bolts on the bottom that holds the part that connects to the pipe to the rest of the silencer if your leak is in that part you should take it apart again re seal with some good rtv and tight again if your leak is on the silencer tip you probably running to much oil in your mix.
