1985 xl 350 cam
Simple question. Can someone give the service limit measurements for the lobes on a 1985 xl 350.  I am parting it out and a dont want to sell a cam if it is out of spec.  Thanks
Carpenter519, I sent you a PM hours ago from the specs I received from an old Honda mechanic of 0.005" wear limit.
From what I found out in a 84 XL 350R Shop Manual they have different specs than the above quoted numbers.
In 30.569 mm (1.2035"), service limit 30.37 mm (1.195"), wear of 0.0085" less.
Exh. 30.575 mm (1,2037"), service limit 30.38 mm) (1.196"), wear of 0.0077" less.
Hope this helps.
Carl.....~~=o&o>.....
