KX 65 Clutch Options ?
Just got my boy a 65. It needs a clutch. With my YZ's I've always had the best luck with OEM plates. DOes the same apply for the 65 ? If not what aftermarket plates would you recommend ?
If your boy is not racing and not hard on clutches then it probably does not matter.  My son probably did about 70 hrs on his KX65 and the original Kawi clutch worked fine. It was his first clutch bike and toward the end he was slipping it for most slow corners. I was using diesel oil in the transmission, the usual "API CI-4+" spec and changing it maybe every 15 hrs.
